Hi guys,
So...I'm almost about to throw in the towel, take out my GPU, and just fling it into the wall...only reason I haven't is that I'm planning to sell the card (worst case scenario I can';t get it to work)...or do a bitch fest to XFX to get them to replace me with either a new R7 260x...or a R9 270 😀...or R7 265.
But really, anyways the situation i'm having is this.
Currently:
First, installed new windows 7 genuine, validated, got all the updates np (just did this yesterday)...put in all my board drivers etc...all worked fine....then....
PRIOR to GPU driver installation (R7 260x), it read the R7 260x as Standard VGA driver, each time I reboot during driver installations, and during windows setup, everything went fine...there was no blackout no screen errors no problems at all (can I say my GPU is fine then? I don't know, thats why I'm asking you experts here)....
THEN....did a backup of my windows (was a wise choice)...then instlaled GPU graphics...seemed okay...it asked me to reboot, so i did...BAM...blue screen of death instantly...with some numbers running at the bottom...and i saw specifically like BEFORE (when I had the windows 7 that was fake and was installed by my friend who said it was real when he charged me for it)...the error on the blue screen with the atikmpag.sys error on boot up....then it basically went back to before, it wouldn't boot up...id simply get a black screen...with either keyboard lights on...or/and id get a single beep sometimes...but nothing on my pc...or i'd get nothing at all except fans running..keyboard light would be off...and monitor black....
i have no idea what is going on now. is it my GPU? is it the GPU driver? is it my BIOs not being up to date? my mobo being too old? my PSU (modular)? the PSU cables?
Here's my specs BEFORE and NOW...
BEFORE
Windows 7 Professional 64-bit SP1
AMD FX-4350 19 °C
Vishera 32nm Technology
8.00GB Dual-Channel DDR3 @ 668MHz (9-9-9-24)
ASUSTeK COMPUTER INC. M5A97 LE R2.0 (Socket 942) 29 °C
HL269DPB (1920x1080@60Hz)
HD RADEON 6450 1 GB DDR3
931GB TOSHIBA DT01ACA100 ATA Device (SATA) 34 °C
1863GB Seagate Desktop USB Device (USB (SATA))
DTSOFT Virtual CdRom Device
HL-DT-ST DVDRAM GH24NS95 ATA Device
Realtek High Definition Audio
Thermaltake 500W PSU
NEW PC SPECS
AMD FX-4350 19 °C
2048MB ATI AMD Radeon R7 200 Series (XFX Pine Group) 41 °C
Corsair CS650M 80 gold standard
So really, between old and new, theres only 3 differences...new PSU (Thermaltake 500W to NOW CS650M 80 gold)...new GPU (HD 6450 to a 1 day HD7770 which bugged like mad...to the newly purchased from a reputable store and warranty'd R7 260x)....and newly installed Windows 7 (old one I was tricked I guess by my friend, but I've nuked my drive COMPLETELY and installed a NEW Windows 7 GENUINE and VALIDATED)
What's going on guys? I have no idea, I'm really frustrated, I've been tackling this problem of being unable to boot up or having to restart my PC about 20 times and power on and off etc in order to get it to turn on once or twice, only to have a 50% chance for it to freeze and blue screen or just stop moving or go black.
I've installed the drivers from my CD for the GPU, I've tried to update VIA ASUS site....I've already tried pressing in the cables in my PC to make sure nothing is loose....my PCIe slot worked fine with the HD6450...and I think it is still right? (Since without drivers, it boots up fine...no errors like this...calling my R7 260x Standard VGA Driver)
I don't know how much more detail I can give, I hope it's not too much information, I'm trying ot be as detailed as I can to help with giving enough information.
Is my board too old? I don't think i've got any hardware problems (being too old)...should I just buy a HD 7850? or a GTX 660? or a R9 270? (HD 7850 is 180+tax, GTX 660 is 190+tax, R9270 is 200+ tax)...
Help guys please....🙁
UPDATE
Just wanted to add that...when I check device manager (before...with the old specs...AND before...with the NEW GPU/PSU)...it always shows that it is fine. always says 'the device is qworking properly' etc...so it doesn't even show an error there (which i assume is good...because that means its not my MOBO error?)
Currently:
BEFORE
AMD FX-4350 19 °C
NEW PC SPECS
AMD FX-4350 19 °C
UPDATE
