R7 Driver Freezing Computer?? HELP! R7 370
austi79
Commendable
Apr 5, 2016
My Windows 10 Pro 64Bit computer recently downloaded an update through windows update, never has an AMD driver come through on this. This time it did, every single time as well, if I try to go to AMD's website or install it from the updater, it freezes the computer up and then the computer won't boot properly, usually having to result in a restore.I want to get rid of it so I don't have to download or install it, I've tried wiping the downloads from the Software Distrobution> Downloads> Delete all, then shut down, but that doesn't work. I tried downloading a tool from Microsoft to hide the update and it's still in the updater. I've read around and others are having this problem but no one seems to know what to do. Help!
https://puu.sh/rXotm/db1918dfe6.jpg <-- Problem
Complete Build: http://pcpartpicker.com/b/DjzMnQ
My Specs:
i7-4790K Quad-Core Processor
R7 370 Radeon Graphics Card from Asus
Asus Z97 Pro Wi-Fi ac Motherboard
16 GB Crucial Ballistix Sport RAM
PNY 240GB SSD (C:)
I highly recommend you install DDU. Which is also known as "Display Driver Uninstaller" . It will prompt you to boot into safe mode and then you can either uninstall either AMD, Intel or Nvidia drivers. This will completely get rid of any residue or files from the drivers and remove them.
DDU: www.guru3d.com/files-details/display-driver-uninstaller-download.html
Then i would go to AMD's website and get their latest drivers. Don't install them through windows otherwise it'll screw everything up
