R9 270x 6 pin plug required?
That's not truth, you can always buy a 4pin Molex to 6 pin power conector converter and problem solved, i've seen people with hd 7970 with power supplys without any 6 pin power conector, from those old withe PSU and everything run just find for almost 2 years. I think they chance old ones, one month ago.
But back to the topic, yes , you will requiere 2, 6 pin PCI express power conector, just have one?, don't worry http://www.ebay.com/itm/NEW-4-Pin-Molex-to-6-Pin-PCI-Express-Video-Graphics-Card-Power-Adapter-/300993997156?pt=US_Power_Cables_Connectors&hash=item4614a3e964
Sorry for my english
In my experience I found out that good PSUs have at least 2x6 pin connectors. If the PSU doesn't have 2 that usually means that it was not designed to power such a card or it may be a bad brand that says 650w on the label but actually delivers less then half. Altough it may be possible I see no reason at all to use those molex adapters because it is a good sign that the PSU is not strong enough for the card and you may damage it.
So true, you should never be using those molex to 6 pins.
that's is correct. You should have a PSU with x2 6 pin power conector. but you can always buy an adapter like my friends did with those 7970 for almost 2 years 😀 if you don't have the x2 6 pin PSU and you only have one. or 8 pin etc.
I got the Molex to 6-pin adapter, installed the card, and had these weird dots all over one of the monitors (DVI only). Here's what it looks like: https://www.youtube.com/watch?v=8JuUHt0OTco&feature=youtu.be
I've since taken the card out because I was worried it might be damaging something. Does anyone have any idea if the adapter or the power supply could be causing this? I don't want to spend money sending the card back to get a new one if a new one will have the exact same problem.
Thanks
