R9 270x running at 90-95 during Civ Beyond Earth
Phoenix91357
39
The card runs at 38 idle temp but goes up to 90-95 during Civ Beyond Earth. The dust was blown off and it has new thermal paste. Are those temps safe? It doesn't go that high in other games. Temp is from Gpu temp
yes that 70-78 is is fine. also if your frame rate is above 60 you might want to enable v-sync. that can also limit your gpu activity and will lower your temps some more.
AMD cards are officialy stated to tolerate temps upto 90-95c
around 75c is usualy the average
if you are too concerned then use MSI Afterburner th increase fan speed to 100% ..it will help
sid myers civilization beyond earth is a very heavy game
have you switched on mantle?
i suggest you to use directx and see if it lowers the temps
mantle usualy gives gpu the work relieving the cpu...
