I currently have 2 monitors, one is running at 1680x1050 and the other is 1366x768. At idle my 270x runs at 52c, and under heavy gaming it gets as high as 80c. 52c seems kind of high for idle with the cooler that Sapphire put on it. My previous Sapphire 7750 idled at 36c.
Here is the card I have:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202050&cm_re=r9_270x-_-14-202-050-_-Product
This brings me to my next question. I have an Asus Xonar DG sound card in the pci slot right next to the GPU and it seems to be suffocating it a little. I know people run sli and crossfire setups like this all the time and their cards are fine. Do you think it would be worth it to take out my sound card and just use the onboard audio to allow my GPU to get some more airflow? My onboard audio chip is the Realtek ALC887. I don't really know that much about the Realtek audio chips other than they aren't usually that great. What's your guy's opinion on them?
