KoalaZed :
A friend of mine gifted me a XFX r9 280 graphics card. I want to use it in my next budget build but am not sure what power supply it needs. On their website it says the minimum is 750 watt but reading other posts, they say 550 watt is enough. What amount do I need?
Hi - As the others have said, a good quality 550w PSU is more than sufficient.
However, I recommend you
avoid the OCZ PSU suggested above. OCZ is in bankruptcy, and
although Toshiba has acquired their SSD assets, I don't believe another company has picked
up the PSU line, so warranty service (or any PSU parts needed) could be a problem.
