r9 280x dual monitor display issue
jnskittles
Hello,
I am using an Radeon r9 280x with two asus vx238 23" monitors. I am using 1x HDMI port and 1 x dvi port. Both monitors are said to be in 1920x1080 in windows and CCC. but the monitor that is plugged into the DVI will not fill the entire screen. The monitor plugged into the HDMI port is working fine.
How can I fix this so that both monitors will run correctly?
Hi,
Open the catalyst control center and goto my digital flat screen then scaling options you should have the choice to adjust the overscan setting for the monitors and this should fix the problem.
beefy
236
Hi,
