[SOLVED] R9 280X fan replacement
yullbarez
Commendable
Jan 17, 2019
201
Hi, i have an Sapphire R9 280X Tri-X OC GPU. It has 85mm-75mm-85mm fans. 85mm ones are dead, i want to replace them.
I'll get 85mm Dual-X fans from local market.
Would it fit on my GPU without problems?
Thanks.
Yeah, they ought to be the same. You can also compare the fan models from the seller and yours, it should be a PowerLogic fan with the same voltage and power
