R9 280x No Signal
jake44264
14
Hi, i have a graphics card (XFX R9 280X Black Edition) and when i put it in the mother board and put it on it says no signal. i have the latest bios, the graphics card works in a different pc, the psu is 850w, i tried a different power supply and i got the same problem. i don't know if there is a problem with the mother board or i have to do something in the bios.
Edit: i contacted Gigabyte using esupport and they said:
"Press DEL get into BIOS --> move to BIOS Features Setup --> Change the PCI ROM Priority to Legacy (default is EFI Compatible ROM) --> Save the setting and reboot.
Please check if your graphics card need VGA BIOS update for UEFI compliant mode."
I tried that but i still get no signal, i have tried 2 Hdmi's & 1 Dvi cable into my R9 280X black edition, i think there is something else what i have to do in the bios.
Specs:
Intel i5 3.20Ghz
8GB of ddr3 ram
Gigabyte GA-H61M-DS2 DVI Motherboard
XFX R9 280x Black Edition Graphics card
Artic blue + 850w
That's what i sent to gigabyte, il edit it
Hi, i have been having a similar problem with my r9 280x, you can try keep pressing F8 when u start your computer and then select the low resolution mode and then playing around with your resolution after you get in. Also, just ignore trolls like that sssssaw guy, his life is miserable and must make himself feel better by insulting others.
if i press F8 i still have no signal.
