I've read the R9 290 runs very hot and loud (I'm not going to OC). Will I be ok with this case in this build: http://pcpartpicker.com/p/f7mtzy Is the Sapphire Radeon version of this card decent? I do not want to have to buy aftermarket coolers. If the 290 will be a problem, what would you recommend for around the same price-range and performance? Or should I just get the GTX 970, or some other GPU? If so what would you recommend? I really don't want to spend that much, though.
