R9 290 problems ( was working fine)
Pyrofan
124
So, i was wondering why my fps was so low when playing games. Opened up MSI afterbuner and CPU ID and here are my results:
GPU1 Usage: 24% ( goes up and down from 24 to 0)
GPU2 usage 0%
GPU 2 VID usage 0 %
GPU fan speed 46 %
GPU1 Core clock 312 mhz
GPU 1 memory clock 1350
and CPU ID only shows one reading now and its TMPIN0 : 42C
What the heck is going on? Did some setting get reset?
SPECS:
i5-3570k
PowerColor R9 290
Corsair 8gb ram
CX750M
HAF 932 advanced
No its a single 290. Still not sure why on CPU ID it only shows one reading for the GPU. Before it showed a bunch. Also, GPU2 does get spikes to 100% for one or two seconds then drops back to zero.
Anyone? Did i burn out a "core" on my GPU? I dont think i did cause i think it wouldnt work at all. I read about some setting when you GPU gets hot it goes and down clocks everything. Did it do that?
