R9 290 tri-x help
maallaoui
Commendable
Jul 29, 2016
4
hello
i have a dell optilex 790 and I have recently upgraded both my GPU and my PSU with an r9 290 tri-x and corsair tx 750 non modular the probleme is my gpu temp is idle on 55C-65C and under load is more than 85C i was wondering what should i do to decrease this high temp and this pictures for my computer
My Specs :
Processor: Intel Core i7-2600 @ 3.40GHz
Ram: 12GB
Graphics card: SAPPHIRE R9 290 Tri-X 4GB OC
Psu : Enthusiast Series™ TX750
Case : Dell Optiplex 790 Mid-tower
Fans : 1 on back side
That case id definitely better than what you have now. Having a larger than needed PSU is not a problem. The PSU will only deliver what the system needs.
^+1.
In the meantime you can try:
Run with the side panel off, as in the photos.
Run a room fan aimed at the lower part of the system to promote better airflow.
Move the HDD shown on the right of the photos outside of the case, use a little double sided sticky tape to hold it against the case with its cables at the top, right now it's picking up a lot of heat from that big R9 290.
Yep, that Sharkoon should help with the temperatures, and will probably be a little quieter-the R9 290 fans won't have to work so hard.
The link provided shows a price in UK Pounds, so I'll guess you're also from the good old UK. 😉 If so, have a look here as well: CCL, Scan, Overclockers, Ebuyer and Novatech, you may find something more to your liking. Just be aware that not all low cost cases come with fans, or may only ship with one, Phanteks, Corsair, Noctua, Cougar, Be quiet! and Noiseblocker all make excellent low noise, high performance fans if you find you need either extras or replacements.
no i'm from tunisia that's located on north africa and in my country there's not really big choices in gaming components and this the link for the store that i will buy from it and i contacted it and he tell me that 3 fans are with case : 2 front and one at back
http://
