r9 290 weird problem ?
SuicidalMind
Commendable
Jun 18, 2016
Hi !
I have a R9 290 and i have a weird problem. THe drivers are ok and the Temp is ok i have a xtreme accelero 3 on it. The problem is when i play a game the card always crash once and after i can play all night long but it always crash once. I dont know why.. i have tried some trick like msi the option Force constant voltage but nothing change.
Any idea what happening ?
thank you
Download DDU and remove everything related to AMD, re plug the card into a different PCIe lane ( if possible ) if not just into the same lane, check power connectors, power on reinstall latest drivers, next step would be to clean windows or try the card in a different system !
