R9 295X2 - AX 860i Enough power?
El Pelican
44
Hi there,
Was wondering if the current psu might just do with the new 295X2?
The 295X2 need at least 50A in both PCIe connectors, the AX 860I has 72A on the 12v rail.
Also, I would be using the new 4790K(not planning to ocing)
4xMechanical drives
2xSSD'S
2X140MM fans
H100i (Push/Pull)
2x120mm fans.
All of these fans will be connected to a fan controller :Aerocool Touch 2100
I think that by having all these hardware connected might just not be enough for the 860i...
Thanks.
There's still room for overclocking , but when I overclock I like to have additional power.
Here's the BEST 1000w on the market.
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($136.81 @ Newegg)
Total: $136.81
Tier 1 Brands - The Most Powerful And Stable Components On The Market.
Antec Signature
Antec High Current Pro -1200w
Antec HCP Platinum 1kW
Cooler Master V series 700, 850, 1kW
Corsair AX
Enermax Galaxy
Enermax Revolution
EVGA SuperNova G2 1000W and 1300W :D
Kingwin...
kalijaga
154
AX860 should be able to handle ONE 295x2.
But if you are going to overclock (even when not planning to NOW), I suggest 1000w. I think shopping around you may find the difference is quite small, and you will have some spare power later when the poison of 4k gaming starts to permeates...
Good luck
El Pelican
44
Hi there Sr 71,
Is there any psu calculator to verify your finding?
If I oc the cpu, do you think I can still use the 860i or do i need to buy a 1000W psu?
I will be using the 4970k devil's canyon.
Dark Lord of Tech
Retired Moderator
Total: $136.81
Antec Signature
Corsair AX
Enermax Galaxy
Enermax Revolution
Kingwin Lazer Platinum
PCP&C TurboCool
PCP&C Silencer Greater than 610 watt
Sapphire Pure
Seasonic X-Series
Seasonic S12D/M12D
Silverstone ZF (Etasis 85/75/56)
Seventeam ST Greater than 600w (SSI, V2.91)
Silverstone OP/DA Greater than 700 watt
Silverstone ZM
Ultra X3 Greater than 1000 watt
XFX Black Edition
XFX XXX Edition
Zippy/Emacs SSL
Zippy/Emacs GSM
Zippy/Emacs PSL
Zippy/Emacs HG2
Zippy/Emacs HP2
El Pelican
44
So, there is no really need to buy a 1KW psu since the ax 860i would be able to handle the 295x2 right?
I'm just concern about the rest of the hardware like the cpu, the fans,SSD/HD,etc.
