R9 380 build, GTX 960 or other build (£580>)
SammyDodger24
Commendable
Apr 26, 2016
38
Build 1: (GTX 960)
ACCESSORIES
Mouse: Perixx MX-1000 Iron = £12
 http://www.amazon.co.uk/gp/offer-listing/B008YFXG9K%3FSubscriptionId%3DAKIAJGZZEZH27SCMC24Q%26tag%3Dpcp0f-21%26linkCode%3Dxm2%26camp%3D2025%26creative%3D12734%26creativeASIN%3DB008YFXG9K
Keyboard: From Tom/Dan or
Logitech Comfort Keyboard K290 - UK layout = £20
 https://www.amazon.co.uk/Logitech-Comfort-Keyboard-K290-layout/dp/B00EE7DVTM#immersive-view_1461590808927
TOTAL OTHER PRICE = £12 or £32
COMPUTER
CPU: i5 4690k= £175
 http://m.ebuyer.com/629960#fo_c=951&fo_k=964f05200218511d5a4058808cea94af&fo_s=gplauk?mkwid=sfZfoS9Iv_dm&pcrid=51482416739&pkw=&pmt=
GPU: Egva GTX 960 4gb = £165
 http://m.ebuyer.com/721812#fo_c=951&fo_k=7822ef2d758bcbd2089c9f3aea6c2d17&fo_s=gplauk?mkwid=smjKDo735_dm&pcrid=51482416259&pkw=&pmt=
OS: Windows 10 = £25
 https://softwaregeeks.co.uk/product/windows-10-pro/?gclid=CIWJvovjicwCFY4V0wodoxsHfQ
HARDRIVE: Seagate Barracuda 1TB HHD = £38
 http://www.amazon.co.uk/Seagate-ST1000DM003-inch-Barracuda-Drive/dp/B005T3GRNW
MOTHERBOARD: MSI H81M-P33= £37
http://m.ebuyer.com/567708
MEMORY: 8gb Ram (Crucial) = £24
 http://m.ebuyer.com/480066#fo_c=951&fo_k=7c536f3b63648f2c9c61852e680d0dc0&fo_s=gplauk?mkwid=sWA3N2WiH_dm&pcrid=51630194939&pkw=&pmt=
CASE: NZXT Source 210 (Black) ATX Mid Tower = £34
 https://www.amazon.co.uk/gp/aw/ol/B00JZVTODY/ref=mw_dp_olp?ie=UTF8&condition=new
POWER: EVGA 430W ATX Power Supply = £33
 http://www.novatech.co.uk/products/components/powersupplies/450wandbelow/EVGA/100-W1-0430-KR.html?#utm_source=affiliatewindow&utm_medium=affiliate&utm_campaign=PCPartPicker
WIFI CHIP: i Adapter TP-Link TL-WN881ND = £13
 http://m.ebuyer.com/343318
OPTICAL DRIVE: Samsung SH-224FB 24x DVD Re-Writer SATA (OEM) = £15
 http://www.novatech.co.uk/products/components/opticaldrives/dvddrives/internaldvddrives/Samsung/SH-224FBBEBE.html?#utm_source=affiliatewindow&utm_medium=affiliate&utm_campaign=PCPartPicker
COMPUTER = £570
COMPUTER + Accessories = £580
Build 2: (r9 380)
PCPartPicker part list: http://uk.pcpartpicker.com/p/NvnRpg
Price breakdown by merchant: http://uk.pcpartpicker.com/p/NvnRpg/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£179.99 @ Amazon UK)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard (£37.98 @ Ebuyer)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory (£23.96 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.98 @ Novatech)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card (£169.99 @ Overclockers.co.uk)
Case: Deepcool TESSERACT SW ATX Mid Tower Case (£29.99 @ Ebuyer)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply (£41.99 @ Novatech)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£10.06 @ Aria PC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Wireless Network Adapter: TP-Link TL-WN881ND 802.11b/g/n PCI-Express x1 Wi-Fi Adapter (£12.98 @ Novatech)
Mouse: Perixx MX-1000 Wired Optical Mouse (£15.66 @ Amazon UK)
Total: £560.58
Generated by PCPartPicker 2016-04-30 13:42 BST+0100
Would you use different parts at this budget. Only flexible by a max £10 on £580 - to include Windows 10 at £26
Will it be able to play most games 50 FPS 1080p. Will it be able to play no mans sky? Thankyou in advance.
Thankyou, but which GTX 960 should I use?
In the end, is it about preference though?
Yeah, if you prefer nVidia and don't mind taking lower performance for the same or higher price. Some people don't mind as long as it says the name they like on the side. But from a Price/Performance standpoint, the R9 380 is the better choice. It wins every benchmark.
Personally, I'm a believer in going with whatever has the best price/performance ratio, I could care less about the name on the side. If you were asking about a performance tier lower, I'd be recommending the 950 over the R7 370.
Thankyou, you have finally given me a black and white conclusive answer!
I will look into this.
Anything else you would tweak on the build (changed memory to kingston hyper fury 2 x 4gb)
Sorry for the delay, just got home from an airshow.
The only other thing I personally would change is the motherboard or the CPU. You have the "k" version of the CPU but a motherboard that does not support overclocking. So either change to the non-k version of the CPU or get a Z87 motherboard to open the option to OC.
I would also not get an MSI motherboard, my experiences with them have been bad. I stick to ASUS or ASRock motherboard.
No worries, is this a good motherboard. I notice it has croasfire support so may cone in handy as I will get an r9 card!
http://uk.pcpartpicker.com/part/asrock-motherboard-h81m
Thankyou for the help so far!
My near final revised list:
ACCESSORIES
COMPUTER
CPU: i5 4690k= £175
GPU: SAPPHIRE RADEON R9 NITRO 380 4096MB GDDR5=  £170
  https://www.overclockers.co.uk/sapphire-radeon-r9-nitro-380-4096mb-gddr5-pci-express-graphics-card-with-backplate-11242-13-20g-gx-374-sp.html
MEMORY: Kingston HyperX Fury Black 8GB (2x4GB) DDR3 PC3-14900 1866MHz Dual Channel Kit= £29
 http://www.novatech.co.uk/products/components/memory-pc/ddr3memory/ddr3pc3-149001866mhz/Kingston/HX318C10FBK28.html?#utm_source=affiliatewindow&utm_medium=affiliate&utm_campaign=PCPartPicker
CASE: Deepcool TESSERACT SW PC Case = £30
http://m.ebuyer.com/730082
POWER: EVGA 60)W ATX Power Supply = £43
http://m.ebuyer.com/716703
COMPUTER = £565
COMPUTER + Accessories = £577
Now I have tweaked most things, is there anything else anyone might suggest? I only have am extra £3 budget :/
