R9 380x render problems
PowerNewb
Hey guys, just got my new Gigabyte G1 Gaming r9 380x two days ago and i have been noticing some problems with it. The first one is the biggest imo, occurs when i am in any game, and the "render circle", not sure how its called, but the area that the gpu renders shadows and high quality textures seems very small. For example in gta 5 or beamng, the card only renders high quality textures what appears to be only 20 feet in front of the character. As well, in gta 5, all the textures seem to be shimmering especially shadows. i know that it has nothing to do with heat as my gpu never goes above 65 degrees Celsius even under max load. Any help would be appreciated.
It would be a slider, not so much an on/off setting. Assuming that's the problem, that is.
Someone will correct me if I'm wrong, but I believe that's related to various render distance settings, like specularity fade or object fade. Try to find those in your in-game graphics options
I already enabled everything in game
