R9 390 FPS issue
Nickner
22
Just overhauled my pc and in every game i play im getting absolutely horrible fps any solutions?
refer to signature for specs
Download GPU-Z and/or MSI Afterburner and use either of them to verify that the GPU and memory are running at full speed. If they are then I have a couple of questions:
1) What were you using before the R9 390?
2) Did you remove the display driver completely before installing the drivers for your new GPU?
3) What's the resolution of your monitor?
4) Mention some of the games you used to test the new card
i have tested with csgo it jumps around between 80 and 100 maxed out when i was getting nearly 200 with the gtx 770
i also tested it with the new hit man beta its hovering between 55 and 65.
1920x1080 monitor
i downloaded ddu earlier today to try to delete my drivers but all i got was files no program
