Okay so I got a couple new parts recently. So let me list my parts and then i will get into the issues.
CPU- AMD FX-8350
Mobo- Asus Sabertooth 990FX
GPU(new) - MSI R9 390
RAM - 8gb G-Skill Ripjaws X
Power Supply - 850w EGVA G2
HDD- 1tb Western Digital Caviar Blue (x2)
SSD(new) - Samsung Evo 250gb
Case- Cosair 450D
Monitors- Dell U2414H (x3) & 1 HD TV
My old GPU- Gigabyte R9 280
Issues: Everything was fine until I swapped out my GPU. My first issue is I can only get one of my monitors (connected with DP cable) and my TV (connected with HDMI) to display anything. The other two moniors are connected with a DVI-D to DP cable (http://www.amazon.com/dp/B004C9O6T6/ref=twister_B00CYQ7BTG?_encoding=UTF8&psc=1). I assume its the cable but i have no idea what to get. I did some research and I know that I need an active cable but my monitors only have these connections:
My GPU has these connections and my DP and HDMI slots are used:
My second issue is when I turn off my computer one of my front LED fans stays on and my H100i stays on (the corsair light on the water block stays on). Even when i turn off my power supply the light and the fan stays on. I have to turn off the power strip that my computer is connected to to actually get the fan and the and the light to go off. I have no idea why this is happening. Any suggestions are welcome!!! Thank you anyone for the help in advance!
CPU- AMD FX-8350
Case- Cosair 450D
