I am trying to play this game on triplehead 5760x1080 resolution, but the ratio is too wide or too zoomed in. I had it working before on CD on my other AMD setup.
http://i.imgur.com/bNVCqhz.png
But as I tried to install by CD on my new full tower Intel setup, I could not get it to even load. Had to rename workermap4 to workermap8. Then after trying 1 week to find a way to force a 21:3, 16:3 or 21:9 aspect, I had no luck but instead seeeing the ratio reset to normal making it impossible to even navigate the menu.
Here is a screen of the highest res I can currently pick.
http://i.imgur.com/1AksHke.png
Now I bought the steam version and when I edited the DATA line in hardware restrictions.XML the game won't even start throwing me a error 80 code. Reinstalled and set in to 1 screen, but it looks so funky playing that on a full driving setup. I really need some help if possible at all. Any suggestion any kind of tip will help at this point.
