Hello!
I'm out of ideas with my display and GPU problem so now I need some help. I have GPU Asus Radeon RX 5700 Dual Evo OC and my display is Asus VG248QE 144hz. My GPU memory clock is all the time super high (3500Mhz) when I put display settings to 100hz or more up to 144hz, doesn't matter if it's idle or am I gaming. Memory clock will drop to 400Mhz if I put display settings to 85hz or less. Display is connected to GPU with DisplayPort. The display image is perfect and everything is working when gaming or doing something else but the high GPU memory clock consuming 2x more power in idle and the GPU is too warm all the time (like 57 to 60 celcius). I've been uninstall all drivers with DDU and installed again and it doesn't fix anything, I even updated BIOS. So does anybody have any idea what I should try next to fix this? Thanks!
Some pictures:
144hz __ 85hz __
Other specs: Motherboard Asus Prime B450-Plus / CPU: AMD Ryzen 5 3600 / 16GB HyperX 3200Mhz
Some pictures:
144hz __ 85hz __
