Question Radeon 5700xt 2nd monitor resolution
Dec 7, 2019
4
I have a dual monitor set up and my displayport monitor works perfectly fine but my second screen going through hdmi 2.0 is stuck at 640x480... I'm unable to change it on the windows display screen or in the radeon software
1st monitor
View: https://imgur.com/ZJg4CE8
2nd monitor... unable to change the resolution.
View: https://imgur.com/aASPhZ9
The 2nd monitor worked fine as the primary monitor up until I started using the display port along with the hdmi.
Raedon Software is up to date 19.12.2
Any help would be appreciated! :)
I'm having the same issue now. I have a 4k monitor I use with DVI and a TV with surround sound using hdmi. Today hdmi just stopped working period on any monitor or tv tried 10 hdmi cables and after going through and manually re installed all drivers it came up but at 640 and shuddering it wont let u change resolution and now it won't come up at all I have the strix 5700 xt my build is like 3 weeks old so it ain't beat up
