Radeon 5770 temp sensor problem
G
Guest
Guest
i bought xfx radeon hd 5770.
i put it in my computer and installed drivers .
and noticed the air that was coming out was too warm to be normal.
so ive been struggling for som hours to find out how to be able to see the temperature :pfff:
i tried first speedfan then lavalys and then the BIOS and im still unable to see the temperature
G
Guest
Guest
forgot to mention some other stuff:
HD 5770 850M 1GB DDR5 DP HDMI DUAL DVI PCI-E
Everest has the ability to do it but im not sure if you need the Ultimate edition or not. Anyway download GPUZ. When its running go to the sensors tab and you will see the temperature displayed. Or if you have not done so already go to the CCC and under overdrive it will list the temps.
Mactronix
G
Guest
Guest
seems like i should not have rushed through the CCC
thanks
but is there a way to make it show on speedfan?
G
Guest
Guest
didnt get any advice for a day or so :/
needsumhelplol
180
If you didn't already, try this (Windows 7 and Vista only); Right click on SpeedFan and select Properties. Check the Run as an Administrator box and click Apply
