G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi,
I have a Radeon 9200 SE 128MB and Windows XP. The driver worked in the
first place. My RAM had some failure and I had to change it. After that
I had to "recover" Windows because the RAM damaged the filesystem. Now
it is not possible to install the driver again. It always told me to
install a normal VGA driver first. I installed the standard Windows
640x480 8bit Driver with the same result. I tried the original driver as
well as the newest driver from ati.com.
Does anybody have a solution for that problem?
Thank You
Christoph
Hi,
Thank You
Christoph
