hlftopdog
56
my 9500 worked fine for quite a while. i cant remember when but after a while on games (and sometimes in windows) i now get artifacts (checkerboard stuff all over the screen) I HAVE NOT done the Softmod as i know some of you will suggest could be the problem and i have tried rolling back the drivers to no avail. is it likely to be cooling as the card just has a fan and no heatsink on it? i can play old games for about 45 minutes before anything happens but directx9 games (max payne 2, CoD) tend to go MUCH quicker.
Any help would be appreciated as to how to sort this out, thanks :)
Anyway of posting the image file?
http://www.apxg11.dsl.pipex.com/artifacts.jpg
there is a link to a screendump of what happens after playin a game for too long :(
<P ID="edit"><FONT SIZE=-1><EM>Edited by hlftopdog on 12/02/03 07:18 PM.</EM></FONT></P>
hlftopdog
56
cmon pls someone help me out b4 the post ends up 20 pages back never to be seen again i even included a link so u cud see what is happening!
your monitor might be at fault to: such as you vga cable is worn inside. pins might be bent; try wigglin the cable to see if you get a difference.
also do you have the vid card overclocked??
if you do set it at stock speeds and if yo must overclock it step up until you get artifacts and back it down so you wont have them. Hopefully this will help.
<A HREF="http://www.cameronwilliamson.com" target="_new">-={Apostalic Alcoholic.}=-</A>
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Checkerboarding on ATi cards is caused by either memory overheating, or memory clocked beyond it's threshold.
<b>BBA 9800 3DMark03 Score =</b> <b><font color=red>5,342</b></font color=red>
<A HREF="http://service.futuremark.com/compare?2k3=1666744" target="_new">http://service.futuremark.com/compare?2k3=1666744</A>
spitoon
248
If you are convinced it is a heat issue, you could look at installing an aftermarket heatsink and fan combo...there are some really good ones out there.
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Neither of those games are DX9. They might require DX9 to play, but Max Payne2 is DX8.1 and CoD is DX7
cleeve
Illustrious
TRy running it with the side of your computer case off, maybe point a fan at it. If it works, your system cooling is insufficient.
Put more fans in it.
________________
<b>Radeon <font color=red>9500 PRO</b></font color=red> <i>(hardmodded 9500, o/c 322/322)</i>
<b>AthlonXP <font color=red>2600+</b></font color=red> <i>(o/c 2400+ w/143Mhz fsb)</i>
<b>3dMark03: <font color=red>4,055</b></font color=red>
hlftopdog
56
thanks for the help, its not monitor ive tried a different one. overheating memory of the computer or of the card itself? also i ran it with side off still happened. COD and maxpayne ... wow they aint directx9... that makes it worse as maxpayne 2 goes after about 20 seconds and COD after about 20 minutes. *worrying*
Thanks again guys
if youre located in the usa and you would like to buy one of those I actually have an extra one, if you wanna give me an offer.
Actually that is what I use on me 9800p and it worx great
cleeve
Illustrious
The problem is caused by an overheating card, but alot of overheating cards are caused by poor case ventilation.
Either way, if you take off the side of the case and blow a fan on the guts of the PC, it should help you diagnose wether it's an overheating problem or not.
________________
hlftopdog
56
it most certainly is overheatin i ran it with case off for about an hour before tryint a game and same thing happened. im in UK so an offer on ur HS/FAN for g-card wood be silly due to shipping costs. ill have to grab one fromt hat website i guess
Thanks alot everyone glad i got to the bottom of this
hlftopdog
56
well incase u guys remember i baught a new cooler... i went for the arctic silent cooler... very nice no probs installing however same issue is still happening... im starting to think maybe my card is nackered? my agp slot is nackered? my psu is 550W so it wont be that i hope as its almost new... im gettin a bit fed up of this whole thing so if anyone thinks they can sort it out and want a new computer my spec is:
Gigabyte GA7N400-L1 Motherboard
512MB DDR 2700
Radeon 9500 128mb (non pro) (normal cooler -- i be keepin the new cooler)
AMD AthlonXP 2400+ with Thermaltake 11+ cooler and fan with ducting Mod
550W PSU
Black case with side window
Blue neon tube
CDRW 52x24x52
DVD 16X
HDD = 60gb + 80gb but i cant format them for some reason (any help there too pls) however if u dont want them as i cant format them ill take money off for ya
Blue + Yellow rounded IDE cables
Issue with g-card as mentioned above... any offers welcome
hlftopdog
56
okies no worries everyone i changed motherboard from Gigabyte - MSI (my old one b4 pointless changeover) and g-card works fine again. must be motherboard issue with 9500 or crappy AGP slot sumat silly like that.
Thanks alot for the help
