Radeon 9600 and Need f Spd Undgrnd2 crash
janneman
8
I hope someone can guide me to get Need for speed undergroun 2 working on my system. It keep on dropping back to the desktop after the splash screen, even in safe mode with the lowest settings on the abit Radeon9600.
My system:
Gigabyte 7n400 pro motherboard
AMD 2400XP
512 Ram
AGP8x Radeon 9600 256mb
I've installed catalyst driver 4.9 but no luck???!!!
Thanx
Don't try gaming in safe mode. Have you tried any other ATI driver? Is your system stable in all other games?
<A HREF="http://service.futuremark.com/compare?2k3=3400555" target="_new"> My</A>
<A HREF="http://service.futuremark.com/compare?2k1=8268935" target="_new">Gamer</A>
<P ID="edit"><FONT SIZE=-1><EM>Edited by Pauldh on 01/08/05 07:36 PM.</EM></FONT></P>
I've tried ati's cat4.1* and 4.7 and 4.9 with no luck yet I've initially had troubles running midnight club2, after and update to catalyst 4.2 it worked with the odd time while playing it dropped back to desktop, but clicking on the taskbar where the program was still running it's gone back to the game where I left of.
I've done directX check and believe that my windows might be the culpret, for my machine is running much slower the past month.
Running on windows xp pro
Thanx
I wont try safe mode again!
Do you have the latest DX? 9.0C
Give the latest catalyst drivers a try, the 4.11 or 4.12. They have versions w/o that crapy control center thing that breaks your computer :)
I was reluctant to upgrade from 4.9 for the longest time. When I made sure I didn't need that control center bs I gave them a try. Everything runs much better now.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
what was the last driver you used that supported the game/games that you play?
"Never underestimate the predictability of Stupidity."
<A HREF="http://www.cameronwilliamson.com" target="_new">-={Psychotic Sociopath.}=-</A>
<font color=blue>R.I.P. O.D.B.</font color=blue>
Thanx you all, I've got it running now.
I've re-installed windows and ati drivers of the cd (Cat 4.12) and dx9c and it's working fine but doesn't seem to like the anti alising setting enabled in the game - screen goes dark. Never the less it running brilliant and what a brilliant game!!!
Keep the sunny side up!
Good to hear you are up and running. With a 9600 pro, messed up AA quality is not a big deal really as the performance hit is proabably too high to use AA anyway. The demo at least was found by many here to stress a 9800 pro pretty bad, even without AA. Fun game huh.
