Question just to make sure I'm safe before I spend money, but I think I am. I'm looking to get a Radeon 9600 Pro for my motherboard, which is a Soyo KT400 Dragon Ultra Black with Athlon XP 2600 and 512 megs of DDR 3200 (having to run as 2700). The motherboard supports 8x AGP, there should be no problems, correct?
Also, I was looking to get on of the Sapphire Radeon 9600s, but there are numerous versions of it aside from the XT and SE, which one would you recommend? If you have a preference other than Sapphire, I'm open to suggestion as well, I've just heard Sapphire is good.
