Ok here goes.
Had a Hercules Radeon 9700 Pro for about a year now. Originally I had big problems with the well-documented ‘infinite-loop’ error, where the pc would just freeze and lock up seemingly at random. A month or two down the line the problem was resolved, can’t remember exactly what I did, but possibly a driver update, or just switching to 4x AGP. Anyway, almost a year later another problem arises, corrupt graphics.
From booting, even the text showing BIOS info is corrupted, as is often the windows loading screen. In windows itself sometimes the graphics are corrupted from the start and sometimes they look fine. If I run a 3d game the graphics are completely corrupted or corrupted within about 3 seconds (don’t know if it’s any 3d game, but Dark Age of Camelot and Star Wars Galaxies both do it). Huge polygons appear out of objects, text is illegible and sometimes small rectangular boxes of ‘corrupt-ness’ run diagonally across the screen. When returning to windows graphics are always corrupted after this point.
Here’s what I have done so far to try and resolve the problem:
Checked and reseated the card itself
Switched power connectors and tried the card on it’s own power connector w/o ‘piggy-backing’
Tried all versions of Catalyst drivers since 3.0 (and some Omega drivers) including completely uninstalling old drivers (even used driver cleaner)
Formatted hard drive and reinstalled from scratch
Playing with just about every option in the ATi control panel (fast writes off, smartgart at 0x, 4x etc etc)
Changing BIOS settings for some possibly related things (USB, shadow RAM etc)
Using Rage3D Tweak to overclock or underclock
Flashed and Updated BIOS
Updated chipset drivers
Changing power supply
….but can’t change motherboard AGP voltage as no option :/
I’ve read a LOT of forum posts about issues with this card, but most discuss the ‘infinite-loop’ error, which I haven’t had for a long time. Nevertheless, I’ve tried many of the suggestions made in those forums to fix my ongoing corrupt graphics problem; to no avail. Also, it’s worth noting that my motherboard uses the ‘Granite Bay’ chipset, which, it appears, is known to cause problems with the R9700Pro, but I have found only a handful of mentions regarding the corrupt graphics issue, and no solutions.
ATi do document the corrupt graphics issue <A HREF="http://www.ati.com/support/infobase/4075.html" target="_new">here</A> , but there is no suggestion other than switching power supply (which I have tried) to solve the problem. Regardless, I’d be surprised if it was a power issue after it has run fine for about 10 months, and started occurring at a time when I had made no changes to the system or hardware.
I really appreciate the quality of this card, but after struggling for weeks now trying to solve the issue I’m getting to the point where I’m about to give up and replace it, which I really don’t want to have to do (it was expensive for a start). ANY advice or suggestions you can make would be very much appreciated.
Here’s hoping...
System Specs:
PIV 2.4, 533FSB MSI GNBMax (MS6565, Intel E7205), 1024mb DDR 266, Hercules Radeon 9700 Pro, SonicFury 5.1, 2* WD360GD (Raptor), WD400JB (Caviar), Yamaha CRW-F1 CDR-W, Hitachi GC7000 DVD, Enermax 460w EG465AX-VE(G) PSU, Coolermaster ATC210cAX-1, 19" Iiyama 1451 Visionmaster, Altec Lansing 5100, Fujitsu FDX310 ADSL Modem. WinXP SP1, DirectX 9.0b
Here’s hoping...
System Specs:
