cdwilcox
12
I recently got an ATI Radeon 9800 Pro. Everything went smoothly until I ran a benchmark using 3dmark03. Then I just got really mad. My score was only 2400!!!!!! My friend's 9700 Pro did 5000. Anybody know how to fix this? Thanks
cdwilcox
12
7N400-L1 mobo
AMD XP 2600+ stock speeds
Mushkin PC3500 Level1 @333MHz
Maxtor 120GB 7200RPM 133
Antec Trueblue 480W
And Radeon 9800 Pro 128 (Built By ATI)
That's my system. Thanks for any help.
pauldh
Illustrious
What driver version?
Check and make sure your advanced display properties are set to ATI defaults and not higher toward max image quality.
Did you install your motherboards chipset drivers before the ATI drivers?
ABIT IS7, P4 2.6C, 512MB Corsair TwinX PC3200LL, Radeon 9800 Pro, Santa Cruz, TruePower 430watt
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Yea...slide your quality settings over to "looks like mud" and re-benchmark.
<A HREF="http://rmitz.org/AYB3.swf" target="_new">All your base are belong to us.</A>
<A HREF="http://service.futuremark.com/compare?2k3=2106920" target="_new"><b>3DMark03</b></A>
cdwilcox
12
I have the driver 4.1. I also got my score up to 3200 by increasing the aperture size from 128 to 256. Also, I have everything set to balanced between performance and quality. I have vertical sync always on. These settings are all the settings my friend used when he got 4700. So, there is something wrong.
agcheavin
255
You need to turn Vsync OFF ! as a general rule vsync is never required in games, or you set it to application on, so if a game needs it, it turns it on. But as a rule, turn it off.
Gary.
note. when your score increased after resetting the agp aperture from 128 to 256 did you adjust anything else ?.
Gary
<font color=red>AMD 2700 XP<font color=red>
<font color=red>Gecube 9800 pro Extreme<font color=red>
<font color=blue>ASUS A7N8X deluxe<font color=blue>
<font color=blue>1024 meg Dual Channel DDR 3200<font color=blue>
pauldh
Illustrious
3DMark03 is far less cpu dependent than 2001se. I'd expect at least 5400-5500 on your system. Are you sure your drivers are set to ATI defaults? Try sliding it down to max performance then. I was over 5700 at default speeds and a slight OC puts it over 6000.
<A HREF="http://service.futuremark.com/compare?2k3=2008951" target="_new"> 3DMark03 no OC'ing</A>
pauldh
Illustrious
Again, did you install the motherboards chipset drivers? At 2000-3200 3DMarks, something is majorly wrong. You don't need little tweaks, you need to find what's wrong.
pauldh
Illustrious
advanced properties, 3D tab, then put a checkmark in use custom. It is in the custom settings.
cdwilcox
12
I have all the mobo drivers installed and all the correct chipset drivers installed. I'm thinking about formatting the computer to see if there is something wrong there. Maybe it just needs a fresh install.
cdwilcox
12
I just ran the benchmark with vertical sync turned to application preference. This resulted in a score of 2992. Still not where it should be. Turning it off also didn't result in a very good score.
GeneticWeapon
Splendid
Jan 13, 2003
5,795
Set AA & AF to 'aplication prefrence'.
cdwilcox
12
It was the ATI drivers that was causing a problem for some reason. With catalyst 4.1 I got around 2800, but with the 3.10 drivers I got 4800. Which is better. Thanks for the help.
pauldh
Illustrious
Maybe somthing didn't get installed properly, or more likely it was a setting you had within the drivers. I have used both 3.10 and 4.1 without any significant performance changes. Glad you're up and running quicker now.
Stinkfinger
257
I have a crappy Dell, 1.7 P4, 512 rdram and Asus ATI 256 Radeon 9800Pro. Default settings i scored 5090. overclocked the card 398/380, 714/680. Quality instead of high quality. vsync off, AA & AF to APP pref. Scored a 5338. Used the Drivers on disc that came with card.
2001 scores i can only get about 10,000 and change,
going to build new rig with AMD 64 3200+ cant wait!!!
Confuscious say: He who go to bed with ithcy ass, wake up with stinkyfinger
