Radeon 9800Pro Power connector
oymd
400
Is it necessary to conect the 9800 AND the HARDDRIVE to the SAME power connector as it is shown in the diagram on the antistatic bag???
Reason for my SILLY question is that I THINK my 2D applications open and LOAD a little faster when the card and the Harddrive are on SEPARATE connectors???
Obtuse
377
I recall hearing the NVidia 6800U originally needed two molex connectors for power, and that the connectors could only connect to the gfx card and fans because the card needed so much juice. I've never heard anything else any other gfx card needing a dedicated molex. That being said, if you are really curious that hooking up your card to your HD is slowing you down, you could use a voltmeter to measure how much your card is pulling when daisy chained to the HD and when seperate. If it pulls less when daisy-cahined, voila!! You know. Chances are its not though. But if you have enough molex to have the card on a seperate connector, leave it that way for your own peace of mind.
"The only way to overcome temptation is to yield to it" - Oscar Wilde
GeneticWeapon
Splendid
Jan 13, 2003
5,795
You can use any available plug. I do anyway's.
<A HREF="http://rmitz.org/AYB3.swf" target="_new">All your base are belong to us.</A>
<A HREF="http://service.futuremark.com/compare?2k3=2216718" target="_new"><b>3DMark03</b></A>
Obtuse
377
I was simply saying the only time I've heard of a power restriction on which molex could be used is for the 6800. So, it doesn't seem likely that he would take a performance hit from hooking up his gfx card to a molex daisy-chained off his HD.
cefoskey
440
Cards since the 9700 have been using a power connector, just the FDD version until recently a full molex. Theres no way that connecting them in series or off independent leads would have any effect on data transfer.
"Who is General Failure, and why is he reading my drive?"
P4 3.0 HT, Intel D865GBF, 512MB Crucial PC3200 DDR, WD 36GB Raptor 10,000RPM, BBA Radeon 9600PRO, SB Audigy, Hauppage WinTV
Mindwarper
51
I wouldn't worry about it. I have no open power cables and divided one of my drives without any problems. Well, actually I did have problems, but it wasn't power. I had to reinstall os to get good performance. Good Luck
Asus p4533c 2.53,4x512 1066,40gb system ,240Gb RAID A/V Drive,80 Gb Export,Radeon 9800 Pro,Matrox Rt.X100,Santa Cruz Turtle Beach,Aardvark Aark 20,Ricoh Mp5125a,Samsung 40x cd,Antec w/400,Xp pro
