I'm waiting on a used HP DC7900 SFF E8400 PC (4GB) to arrive to upgrade from my current HP DX6120 machine. I'm planning on running a 128GB SSD drive for operating system and programs, and a 500GB HDD for documents etc.
I intend to use my current Radeon HD 5450 1GB 64-bit low profile graphics card to run dual monitors, 1 in landscape mode 1 in portrait mode. I'm looking for advice on the best way to connect them up. I'm not into gaming, but I do a little design work and the occasional bit of graphics work in Gimp, plus internet browsing and Office documents.
For graphics options, the DC7900 has 1 x PCI-e X16 slot, 1 x PCI Express X4 slot,
1 x PCi-e X1 slot, an HP Displayport, and a VGA connection.
My understanding is that the Radeon HD 5450 supports dual monitors, so I've ordered a dual DVI-D adapter so that I can plug both monitors into the card.
My monitors have DVI-D and VGA connections, so I don't think I can use the Displayport with my monitors?
The PCI Express X4 slot is documented as a graphics slot?, but should I use the PCI-e X16 slot for extra speed?
Any advice would be appreciated!
Other plans include audio card in the PCI slot, and a USB 3.0 card in the PCI-e X1 slot.
Thanks
Chris
Thanks
Chris
