Radeon HD 5770 Triple Monitor Problem
glbracer
I've looked at about every thread regarding this issue and they all say about the same thing; Get an active DisplayPort adapter. Well I think my situation is a bit different?
I have three monitors, 2 DVI, and one DisplayPort adapter that runs has an HDMI connector on the end that plugs into my monitor. Here's where I think it's different. The monitor that's running the DisplayPort adapter is my main one, I'm typing on it right now. I don't know if the card is channeling the other DVI and the DisplayPort, or what. The 2nd DVI monitor is the one that isn't working. Windows and CCC detect it but won't allow me to enable or anything.
Do I still need an active DisplayPort adapter or is the issue something else?
hello there im not sure exactly sure what card you have but that one should have 2 dvi ports 1 display and 1 hdmi so why would you need an adapter? just plug up 3 monitors to each one of the default ports on the card and it should work; but then again maybe your graphics card only supports 2 displays and not 3. or if you dont get this problem solved you can always buy a new card.
