Radeon HD 6670 DVI to VGA not working
MaizeMan112
I'm having any issue with my Radeon HD 6670 not giving any output thru my DVI, I'm trying to run dual monitors and both only have a VGA Input, VGA to VGA works fine and if I use the HDMI to my Xbox monitor it works buy no look with the DVI-VGA converter, Running Windows 8 and don't see any setting in Catalyst Control Center. Thanks
You cannot run DVI-A and VGA at the same time on the HD 6670, since it only has one RAMDAC, unfortunately, you will have to buy an Active DVI-D or HDMI to VGA converter, or you just find a screen that supports DVI-D.
DVI-A stands for DVI-Analogue, it is a backward compatible signal that is the same as VGA, so it is basically VGA signal, but on a DVI connector.
DVI-D stands for DVI-Digital, it is pure digital signal on the DVI connector.
A Passive converter is just basically a cable that puts the pins differently where it "should work".
An Active converter is really converting the signal, but they cost much more $.
Be sure that it is DVI-D, not A.
Hope it helps!, :)
-Bloc97
