Radeon HD 6870 or GTX 470 for my Build
nmeseth
112
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102909
Radeon 6870
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550
GTX 470
1 x ASUS M4A78 Plus AM3/AM2+/AM2 AMD 770 ATX AMD Motherboard
1 x XFX HD-577X-ZNFC Radeon HD 5770 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
1 x Antec Basiq BP500U 500W Continuous Power ATX12V Version 2.01 Active PFC Power Supply
1 x AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGIBOX
1 x G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK
1 x SAMSUNG 22X DVD±R DVD Burner Black EIDE/ATAPI Model SH-S222A - OEM
1 x Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
1 x Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
I will be buying a new heatsink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
Performance wise they are basically tied, the GTX 470 leads a little in avg frames while minimum frames are higher by a pretty good margin on the 6870.
Price, the 6870 is $10 cheaper on Newegg.
Power Draw:
You have the 6870 being less than HALF of the GTX 470's power draw since that diagram is the whole system, and the graphics card doesn't take up a supermajority of the power draw unless you have CF/SLI.
You have the 6870 being a solid 15 C less.
The 6870 is...
sabot00
2,387
Power Draw:
The 6870 is quieter by a decent amount.
So:
Performance - Same
Price - 6870
Temp - 6870
Power Draw - 6870
Noise - 6870
Features wise they both are loaded.
nmeseth
112
I'll go with the 6870, and probably upgrade my motherboard so I can get another 6870 in the future.
What is the deal with upcoming gfx cards coming out? should I wait for a price drop?
