Radeon HD 7770 Vs. ZOTAC GeForce GTX 560 1GB GDDR5
bryced185
Could I use the Gtx 560 with an AMD fx- 6300 amd cpu. I plan on over clocking the AMD fx- 6300 to 4.1 ghz would this cause a problem? I plan on using the card for gaming purposes games such as mmorpgs. I know that the GTX 560 is a better card its just that I'm not sure if it will work with an overclocked amd cpu.
or Radeon HD 7770
http://www.hwcompare.com/11885/geforce-gtx-560-vs-radeon-hd-7770/
I know that based off of this website also, I'm just a little new to building computers honestly and I'm not sure if overclocking the cpu would harm the Gtx560 ( not ti ). I'm thinking it would be okay just not positive.
What model would you recommend of the gtx560? There are just so many it's hard to pick... Thanks for the previous help
