Well hello there!
So, I`ve recently installed a second sapphire 7850 graphics card and I have some questions. First of all I had major problems just starting up the pc, screen froze, disconnected xfire bridge and then everything back to normal.. Anyway after 2,5 hours of troubleshooting it seems to run smoothly now (Don`t ask me what I did cuz honestly, I have no idea)
Okay, so... I just installed trixx and looked at some of the info and I noticed the drivers, bus width, interface and shaders are not the same.. So I wanted to post the info here and hopefully have some of you more experienced broskis to have a look and hopefully tell me I shouldn`t worry too much
About the drivers, shouldn`t both cards run off the same driver? If thats not the case, is it prefered to have another driver for the second card? and how would I even get 2 of the same drivers
Report 1 :
Report generated on 06/08/13 04:00:13
Card name: AMD Radeon HD 7800 Series
GPU: Pitcairn
Device Id: 1002-6819 : 174B-E221
Die Size: 212 mm²
Bus Interface: PCI-E 3.0 x16 @ x16 1.1
Memory Size: 2048 MB
Memory Type: GDDR5
Memory Bus Width: 256 bit
ROPs: 32
Shaders: 1024 Unified / DirectX 11.1
Driver Version: 12.104.0.0 Catalyst 13.4
BIOS Version: 015.022.000.000.000000
BIOS Part Number: 113-221PROHE-S03
Clocks: 950 / 1200 MHz
Report 2 :
Report generated on 06/08/13 04:00:21
GPU: Pitcairn
Die Size: 212 mm²
Bus Interface: PCI-E 3.0 x16 @ x1 1.1
Memory Type: GDDR5
Memory Bus Width: 32 bit
ROPs: 32
Shaders: 2048 Unified / DirectX 11.1
And all of this is running on
AMD FX 8350 OC @ 4,2ghz
Sapphire HD 7850 x2 xfire
corsair cx 750w bronze standard psu
asus m5a97 mobo
corsair vengeance 8gb @ 1600 mhz
Does this look fine to you ?
Greetings from Norway!
Report 1 :
GPU: Pitcairn
Die Size: 212 mm²
Memory Type: GDDR5
ROPs: 32
Report 2 :
GPU: Pitcairn
Die Size: 212 mm²
Memory Type: GDDR5
ROPs: 32
asus m5a97 mobo
