Radeon HD 7870 not working
stg0
14
I have just got a new graphics card, the Radeon HD 7870 and when I put it in and booted my PC up it refused to even get to bios. I am certain is isn't a PSU problem as I just got a new 750W corsair PSU.
Does anyone know what the problem could be? Any help would be great, thanks!
1)Remove the gpu , plug monitor cable to mobo's onboard output
2)start pc - go to device manager - display - uninstall whichever drivers is
3)restart pc - put gpu back
or
1)go to bios settings - set primary display device to PEG OR PCI E or you have an Option "Primary Graphics Adapter" and you want to set it to PCIE->PCI->IGP.
or
1)Update your bios to latest
or
1)make sure you have connected vga or dvi cable from GPU to monitor not onboard on mobo to monitor
or make sure you have connected 6 pin connectorrs fromm psu to gpu
Specs:
-Intel i5 3570k processor
-Radeon HD 7870 graphics card
-Gigabyte B75M-D3V Motherboard
-8GB Corsair 1600Mhz RAM
-Corsair CX750 750W PSU
-2TB Seagate Hard drive
