dedlight Honorable Dec 26, 2012 11 0 10,510 Dec 26, 2012 #1 Hello, just got done playing bf3 and i checked my temp on the radeon hd 7970 and it was 80c, but my fan was at 20% why didnt it speed up to cool it off better
Solution mace200200 Dec 26, 2012 Download a GPU program like MSI afterburner and you can set it manually. Jack it up to like 50%.
mace200200 Honorable Jun 5, 2012 1,697 0 12,160 Dec 26, 2012 Solution #2 Download a GPU program like MSI afterburner and you can set it manually. Jack it up to like 50%. Upvote 0 Downvote Solution
J_E_D_70 Splendid Mar 21, 2012 7,294 59 30,290 Dec 26, 2012 #3 check to see if the manufacturer provides fan/overclock control software and adjust the fan profile with that - or download msi afterburner. Upvote 0 Downvote
dedlight Honorable Dec 26, 2012 11 0 10,510 Dec 26, 2012 #4 ya i can adjust it manually just thought it should do it automatically Upvote 0 Downvote
dedlight Honorable Dec 26, 2012 11 0 10,510 Dec 26, 2012 #5 shouldn't it recognize when its being used and kick on the fans. i shouldn't have to manually turn my fans up when i want to play games Upvote 0 Downvote
reyesdan Honorable Dec 26, 2012 33 0 10,530 Dec 26, 2012 #6 if you can access the BIOS you can fix from there Upvote 0 Downvote
dedlight Honorable Dec 26, 2012 11 0 10,510 Dec 26, 2012 #7 i downloaded that msi afterburner its working alot better then amd catalyst Upvote 0 Downvote
dedlight Honorable Dec 26, 2012 11 0 10,510 Dec 27, 2012 #8 Best answer selected by dedlight. Upvote 0 Downvote
