radeon r7 265 vs radeon 7850
Scott Leess
112
ok buys ive compared these 2 gpu's against each other and theirs frankly not alot of difrrance
the clock speek is slightly higher with afew other bits are higher ie shading and stuff
would this make a diffrance but i will be running these cards in cross fire (buying 2 the same)
any info would help guys
see iv never done crossfire and want to try it every one says use a single card but then ohters are saying buy a single card iv used single high end cards tbf and want to change if not i cna alwas ebang tehm on ebay and put that towards a higher card ie a 4gb or summet
In that case, you should just Crossfire the HD 7850 IMHO.
