Tom's hardware,
I know there are a lot of other topics about the same problem but I cant really find the answer that I need so here I go...
Mobo: Asus H97-Pro gamer
RAM: Kingston HyperX fury 2x4GB
GPU: Radeon R9 270X
PSU: Thermaltake SP-650PCBAU 650W
and other stuff..
Got everything and built it yesterday, works fine if boot from on board graphic but gives "no signal" if GPU is chosen (the computer recognise the GPU as I can see it in device manager) - I have tried with VGA/HDMI on mobo and HDMI on GPU but still no signal
GPU has DVI I & D and HDMI, no VGA. I dont have a DVI cable yet (and from some other posts, problem's solved using a DVI cable).
However before I go out to the store to buy a DVI cable, can someone please advise whether this would be a good idea and what if that doesn't solve the problem? And as to why the GPU not giving any signal when chosen as default?
I'm not a tech guy so if you could use simple terms, that would be highly appreciated.
Thank you!!
GPU: Radeon R9 270X
and other stuff..
Thank you!!
