DImitris1 Reputable Aug 25, 2014 53 0 4,630 Sep 27, 2014 #1 The r9 270x requires 2 6-pin pci e connectors while my corsair cx430 has 1 6pin+2 connector?I am a little bit confused about what is happening right here as they told me i will be able to run this card without any problem. Any possible solutions?
Solution S S SuperChil Sep 28, 2014 Use the six pin pcie provided by the card and connect it to one of the Molex connections. Job Done
rockie_ Splendid Sep 20, 2014 6,022 0 27,960 Sep 27, 2014 #2 CX600 http://pcpartpicker.com/part/corsair-power-supply-cx600 Upvote 0 Downvote
DImitris1 Reputable Aug 25, 2014 53 0 4,630 Sep 28, 2014 #3 rockie_ : CX600 http://pcpartpicker.com/part/corsair-power-supply-cx600 out of my budget. Upvote 0 Downvote
rockie_ Splendid Sep 20, 2014 6,022 0 27,960 Sep 28, 2014 #4 http://pcpartpicker.com/part/evga-power-supply-100b10500kr Upvote 0 Downvote
R Reyoch Ch Reputable Jul 31, 2014 89 0 4,630 Sep 28, 2014 #5 I have msi r9 270x 2gb..recommended psu 500w and i have corsair vs550w its working high performance. And it have 6pin 2..buy corsair vs 550w. R9 270x must want two 6 pin then only it work.. http://www.corsair.com/en/vs-seriestm-vs550-550-watt-power-supply Upvote 0 Downvote
S SuperChil Honorable Jul 8, 2013 68 0 10,640 Sep 28, 2014 Solution #6 Use the six pin pcie provided by the card and connect it to one of the Molex connections. Job Done Upvote 0 Downvote Solution
