Hello,
I am sorry if there is an answer here somewhere. I've been searching for a long time on this subject and i'm not quite sure what the problem is.
I am experiencing a reduction of around 20-30fps on average when I play games with both of these graphics cards installed.
This did not occur when I had the 280X plugged into two monitors and a USB display adapter for my third monitor.
The set up that I have right now:
HDMI cable to Radeon R9 280X to primary monitor
1x DVI and 1x D-SUB to other two monitors
I have updated to the latest catalyst drivers for the Radeon R9 280X and the Radeon HD 6450 is recognized by the software with no issue.
Is the second card somehow limiting the performance of the main card? Is there a possible way to fix this issue that I'm having with the noticeable FPS drop?
Thanks in advance.
System specs and other information:
Operating System: Windows 10 Home 64-bit (10.0, Build 10240) (10240.th1.150729-1800)
Processor: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (4 CPUs), ~3.3GHz
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
ASRock P67 EXTREME4 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model
Brand
ASRock
Model
P67 EXTREME4 (B3)
Supported CPU
CPU Socket Type
LGA 1155
CPU Type
Core i7 / i5 / i3 (LGA1155)
Chipsets
Chipset
Intel P67
Memory
Number of Memory Slots
4×240pin
Memory Standard
DDR3 2133(OC)/1866(OC)/1600/1333/1066
Maximum Memory Supported
32GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 2.0 x16
3 x PCI Express 2.0 x16 slots (PCIE2/PCIE4: single at x16 or dual at x8/x8 mode; PCIE5: x4 mode)
PCI Express x1
2 x PCI Express x1
PCI Slots
2 x PCI Slots
Video Cards:
XFX Radeon R9 280X R9-280X-TDFD 3GB 384-Bit GDDR5 PCI Express 3.0 x16 CrossFireX Support Double Dissipation Edition Video Card
Brand: XFX
Model: R9-280X-TDFD
Chipset
Chipset Manufacturer
AMD
GPU
Radeon R9 280X
Core Clock
850MHz
Boost Clock
1000MHz
Stream Processors
2048 Stream Processors
Memory
Memory Size
3GB
Memory Interface
384-Bit
Memory Type
GDDR5
3D API
DirectX
DirectX 11.2
OpenGL
OpenGL 4.2
Ports
HDMI
1 x HDMI
DisplayPort
2 x Mini DisplayPort
DVI
1 x DL-DVI-I
1 x SL-DVI-D
Details
Max Resolution
ANALOG: 2048 x 1536
DIGITAL: 2560 x 1600 (DVI); 4096 x 2160 (HDMI;DP)
MSI ATI Radeon HD6450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card R6450-MD1GD3/LP
Model
Brand
MSI
Model
R6450-MD1GD3/LP
Interface
Interface
PCI Express 2.1 x16
Chipset
AMD
GPU
Radeon HD 6450
Core Clock
625MHz
Stream Processors
160 Stream Processors
Memory
Effective Memory Clock
1333MHz
Memory Size
1GB
Memory Interface
64-Bit
Memory Type
DDR3
3D API
DirectX
DirectX 11
OpenGL
OpenGL 4.1
Ports
HDMI
1 x HDMI
D-SUB
1 x D-SUB
DVI
1 x DVI
Details
RAMDAC
400 MHz
Max Resolution
2560 x 1600
CrossFireX Support
No
Cooler
With Fan
System Requirements
Minimum of a 400 Watt power supply.
Dual-Link DVI Supported
Yes
HDCP Ready
Yes
Thanks in advance.
Model
Brand
ASRock
Model
P67 EXTREME4 (B3)
Supported CPU
CPU Socket Type
LGA 1155
CPU Type
Chipsets
Chipset
Intel P67
Memory
4×240pin
Memory Standard
32GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express 2.0 x16
PCI Express x1
2 x PCI Express x1
PCI Slots
2 x PCI Slots
Video Cards:
Brand: XFX
Model: R9-280X-TDFD
Chipset
AMD
GPU
Radeon R9 280X
Core Clock
850MHz
Boost Clock
1000MHz
Stream Processors
Memory
Memory Size
3GB
Memory Interface
384-Bit
Memory Type
GDDR5
3D API
DirectX
DirectX 11.2
OpenGL
OpenGL 4.2
Ports
HDMI
1 x HDMI
DisplayPort
DVI
1 x DL-DVI-I
1 x SL-DVI-D
Details
Max Resolution
ANALOG: 2048 x 1536
Model
Brand
MSI
Model
R6450-MD1GD3/LP
Interface
Interface
PCI Express 2.1 x16
Chipset
AMD
GPU
Radeon HD 6450
Core Clock
625MHz
Stream Processors
Memory
1333MHz
Memory Size
1GB
Memory Interface
64-Bit
Memory Type
DDR3
3D API
DirectX
DirectX 11
OpenGL
OpenGL 4.1
Ports
HDMI
1 x HDMI
D-SUB
1 x D-SUB
DVI
1 x DVI
Details
RAMDAC
400 MHz
Max Resolution
2560 x 1600
CrossFireX Support
No
Cooler
With Fan
System Requirements
Yes
HDCP Ready
Yes
