[SOLVED] Radeon RX 460 Not working
Oct 8, 2018
I downloaded the official Radeon graphic update on the client already on my PC so it wasn’t a virus or anything. Then I restarted my PC and the blue screen of death popped up and I tried literally everything. I ended up wiping the PC completely and once I did that windows wasnt working. I tried a recovery drive and that just took me to a command prompt looking thing. I then decided to instal Ubuntu Linux and use integrated graphics to at least be able to use my PC. Once I did that my pc runs fine off Linux but doesn’t work when I have my hdmi in my GPU slot. The PC was a gift from my friend and I had used it for months with no problems beforehand. I’m not the best with PC terminology but know enough to get by at least. I really don’t know what I can do to make this GPU work.
Pull the GPU.
Get your system working with the built-in graphics via the motherboard.
Then try the RX 460 again. It may or may not work. If not then it has failed.
