Question Radeon RX 580 and Skyrim settings
DWF
16
I have an AMD rx 580 running on an i7 Win 10 pro system.
The video card installs its own settings app to the task bar. The gaming section allows you to scan for and set up a setting for games...in this case Oldrim.
Does anyone know what the optimal setting should be?
Skyrim doesn't run correctly on the default settings.
Right now I have the" Radeon Anti-lag" on and "wait for vertical refresh" off except if the application specifies it. Those are the only setting I have changed from the default.
What resolution?
Do you have a variable refresh rate (FreeSync) monitor?
What are your FPS with your current settings?
What settings got applied at default?
"Doesn't run correctly" is not information we can use.
