[SOLVED] Radeon RX 580 Low FPS with low settings for Warzone
Dec 27, 2020
4
I'm getting on average 70-80 FPS even going as low as 60 FPS on Warzone while on 1080p low settings. I've seen a few youtube videos where people are getting higher frames with this gpu. Please help!
CPU: AMD Ryzen 7 2700 Eight-Core Processor 3.2 GHz
Motherboard: B450 GAMING PLUS Max
GPU: Radeon RX 580 Series
VRAM: 8192 MB GDDR5 2000 MHz
RAM: 16 GB
techpowerup-gpu-z-jpg.181209
My ram is 1333 MHz 🙁 and yes it is dual channel. I will look into buying faster ram. What is XMP and where do i find it? Thanks
It's RAM overclocking, it goes by names other than XMP at times, and you find it in either your motherboard software settings or in your BIOS. In your case, it sounds like what you have needs to be upgraded; Ryzen CPUs perform very slowly when not equipped with fast RAM.
I'm guessing your system RAM speed is too low; you're using dual-channel memory right? Make sure you have XMP enabled. If your RAM isn't rated to run at 3000 MHz or better, you should buy some 3200/3600MHz RAM.
