G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.flight-sim (More info?)
Hey gang,
I got home late this evening, and have not had a chance to test it long, but
right now it looks promising.
For the first time, I am able to run water on it's perfect setting with
OpenGL, without texture corruption. I emphasize so far, only ran it for app
10 minutes.
I installed PF patch 3.04, and updated my Catalyst drivers to the latest 5.1
drivers.
Changed the PF setup to OpenGL, set water to 1 in the config.ini file, and
launched the game. Once in the game , I changed landscape detail from
excellent to perfect.
Launched a mission from the carrier - water looked fantastic - big time wow
factor for me, as this is first time I was able to run it without texture
corruption.
Spent the 10 minutes flying low over the water, canopy open, and buzzing the
ships. Man, did it look good!
Framerates - 30 fps on carrier, 50 - 60 fps low and buzzing, 70 fps higher
up in the air. Resolution was set at 1280x960, no aa and no af. I am
confident it will perform the same in 1600x1200.
Anyone who, like me, has been missing out on perfect water, you might give
the latest cat's and patch a try.
Don Burnette
"When you decide something is impossible to do, try to stay out of the way
of the man that's doing it."
Hey gang,
10 minutes.
drivers.
corruption.
Don Burnette
