[SOLVED] Radeon XFX 560 display driver not installing
Aug 30, 2021
23
I am trying to install the drivers for my Radeon XFX 560, and get the following message "display drivers failed to install". In Device manager, it says " Windows has stopped this device because it has reported problems Code 43
What is causing this, and how can I solve it
Make and model of your PSU and it's age? What version of Windows 10 are you using at the time of writing? If you're not on Windows 10, please state the OS you're on. Make and model of your motherboard and it's BIOS version? If you're on the RX 560 GPU, might want to source the drivers form here. Use DDU to uninstall all GPU drivers, then reboot into Safe Mode then manually reinstall in elevated command, i.e, Right click installer>Run as Administrator.
I will do that. Also, The icons on the desktop are all large (kinda how they would look in safe mode) I wonder if the power supply is not putting out enough to allow the full install, and is in some sort of a "default" graphics mode
I ran GPUZ , and it showed the RX 560
