Radiation problem
MelaOS
13
I have a 3.3V, 25A PSU with MSI KT4V mobo, athlon xp2200.
Since i've built this pc myself, i'm not sure about the wiring stuff.
But my problem is this:
Whenever i sat in front of my pc i feel very hot very sudden. And if i try to touch the casing of my
cpu during run time, i will get shocked...
Can anyone lend me a hand on how to fix this problem??
What can i do or buy to remedy it?
Thanks in advance
Static problems in the house? Or do you mean a steady shock?
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
It feels like a slight electrocution, so what could it be?
The casing of the CPU, even when i connect a usb digicam into the back of the cpu, i can get minor shock(feels like a small tingy burning sensation in the fingers) throught the screw or metal part of my digi cam.
Am i missing some ground wires? Cos once i open the left side casing and while the system is still on i try to close back the casing by sliding in the left panel. But the wave was so strong(slight electrocuted feeling) when i try to move the casing near the cpu that i just had to let go of the left panel....
Sounds like the third prong isn't grounded. It's supposed to be grounded to the wall socket via a 3 conductor cable.
Sorry for being ignorant, but could you please be more specific on what is that and what should i check for?
Is your cord connected to a 3-prong wall outlet? If so, you should check to make sure the 3rd prong is grounded.
You can use a volt meter, or buy an electrical socket tester...
Some UPS's have a light/buzzer that when you plug it into an incorrectly wires outlet, it goes off.
_____________________________________________
<font color=red> And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign </font color=red>
If you're using a 3->2 prong adapter, screww the little metal tab on the adapter into the electrical outlet.
Mobile XP 2600+ (11X200)
Abit NF7-S v 2.0
Maxtor 60GB ATA 133 7200RPM
512MB Corsair Twinx 3200LL
BBA 9800 Pro
Enermax Noisetaker 420 watts
Win2K sp4
