Dear all, I'd like your suggestion on a matter of mine.
I have the followings
1) Cougar Panzer Max case
2) Arctic Liquid Freezer 360 (6 x Fans Push-Pull)
3) 3 x 140 Noctua IPPC fans
4) 1 x 120 Noctua IPPC fan
My original plan was a common setup, Front: 3 fans as intake, Back: 1 fan as exhaust, Top: radiator on Push-Pull as exhaust.
But unfortunately the motherboard placement on the case is too close on top so I can't setup the Radiator on push-push.
I have in mind 2 options.
1) Same setup but setup the radiator on pull only.
2) Place the radiator in front. In this case I don't know what is better. Use it as intake and keep the rest the same? Or use it as exhaust and all the other fans, back and top, as intake.
What do you think it would be better? Do you have any better idea. Thanks all in advance!
