So originally I was going to get the Corsair 460x RGB case with a Kraken x62 cooler which has a 280mm radiator. But today I went into a PC shop and the guy there pointed out the case only supports 120mm; 240mm; 360mm (PC Part Picker compatibility didn't pick this up). So my confusion here (I'm a first time builder) is that, why does it say it can support 240 and 360, but not 280 if 360 is bigger?
My second question - A white version of the 460x says it CAN support 280mm, while the black case says it can't even though they have the same dimensions, name and model (by the looks of it)
Here is the page for the 460x black LINK
And here is the page for the 460x white LINK
So which is true, does the black case have an error in information which is why PC Part Picker didnt pick it up, is the white one incorrect, or are they actual different models inside even though they're named the same?
