quakebo Distinguished Nov 9, 2013 55 3 18,535 Sep 12, 2021 #1 Does anyone know if you can fit a 240mm radiator with 25mm fans in the top and same in the front of a Fractal Design Focus G when the two 5.25 drive bays have dvd/blu ray drives in them?
Solution jeremyj_83 Sep 13, 2021 Best answer I can give is based on what Fractal Design says. Their specs say that the top can support a 240mm radiator and doesn't mention anything about 5.25" bays being in the way. https://www.fractal-design.com/products/cases/focus/focus-g/black/
jeremyj_83 Glorious Aug 23, 2017 5,405 1,962 44,440 Sep 13, 2021 Solution #2 Best answer I can give is based on what Fractal Design says. Their specs say that the top can support a 240mm radiator and doesn't mention anything about 5.25" bays being in the way. https://www.fractal-design.com/products/cases/focus/focus-g/black/ Reactions: quakebo Upvote 0 Downvote Solution
quakebo Distinguished Nov 9, 2013 55 3 18,535 Sep 13, 2021 #3 thanks for the reply I will look into it more. Upvote 0 Downvote
